Old 03-28-2014, 01:18 PM   #1
Originally Posted by scumfromohio View Post
There's no smell of coolant inside the car or from the vents. It's hard to say about wetness under the hood cause I'm not the most accurate coolant pourer. Haha so I've spilled a bit. I'll check for foaminess tonight. I was thinking about renting a pressure tester tomorrow and giving that a shot what do you think? Thanks for all your help man.
Sent from my SCH-I545 using Tapatalk
Pressure tester might not be a bad idea. Also, I have noticed that if you disconnect the radiator with hoses that are a few years old and reuse the hoses, that they often don't reseal well unless you replace the stock hose clamps and tighten the heck out of them.
Old 04-01-2014, 07:27 PM   #2
scumfromohio
Drives: 08 White Yaris
OK so pressure test was fine it stayed the same pressure for 10 minutes. We ran it for a good while and after an hour or so coolant started coming out the reserve again, but the filler neck and radiator cap are both brand new.
scumfromohio is offline   Reply With Quote
Old 04-01-2014, 08:48 PM   #3
Coolant will go into the reserve tank as it gets hot and expands. Is it overflowing the reserve tank?
Old 04-01-2014, 08:52 PM   #4
scumfromohio
Yes, its over flowing the reserve tank. That's the only place I can think I'm losing the coolant. When I seen it, it was only a little bit, but it has to be going somewhere ya know.
Old 04-01-2014, 09:38 PM   #5
If it starts at the "cold" level in the reserve tank and then overflows it when the engine is hot, then you still have air in the system. Air expands far more than coolant does, so the air bubble pushes the coolant out.
Old 04-02-2014, 01:58 AM   #6
scumfromohio
I was burping it for over an hour tonight. I noticed that whenever the fan in the front of the car would turn on or I would turn on the heat the coolant which I filled to the top would lower a good amount. So at first I thought it was just air bubbles, but then I noticed a growing puddle underneath the car. I'm wondering if it's dumping when the fan turns on or heat is on. Maybe the heater core. But shouldn't that dump inside the car? Idk, I know the pressure test came back no leaks.
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Yaris problems and solution ubospawis Middle East 26 01-12-2011 03:41 AM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
