Old 03-28-2014, 01:28 PM   #1
The OEM Toyota ones are Continuously Variable Capacity Type Rotary Compressors.
I am not sure if other compressors from other Toyotas would fit the four mounting points of the Yaris engine. Also, many of the larger Toyotas use 6 rib belt pulleys, as opposed to the 4 rib of the Yaris.
Old 03-28-2014, 01:45 PM   #2
jcboy
Drives: Sedan 07
i dont know a thing about our Yaris' compressors, but if your mechanic can transplant a compressor "hub" for a non-Yaris compressor (to fit the 4-rib belt) as well as a bracket for the Yaris' mounting points, then i'll say rotary compressors are definitely the better-cooling car compressors (from what i've heard)
air conditioning, compressor, cooling, rotary
Rotary Hydrogen Mazda Bob Dog Off-topic / Other Cars / Everything else Discussions 0 09-03-2009 05:45 PM
350HP on 2ZZ-GE? forpinks Performance Modifications 42 04-02-2007 11:01 AM
