The OEM Toyota ones are Continuously Variable Capacity Type Rotary Compressors.
I am not sure if other compressors from other Toyotas would fit the four mounting points of the Yaris engine. Also, many of the larger Toyotas use 6 rib belt pulleys, as opposed to the 4 rib of the Yaris.
| Tags |
| air conditioning, compressor, cooling, rotary |
| Rotary Hydrogen Mazda | Bob Dog | Off-topic / Other Cars / Everything else Discussions | 0 | 09-03-2009 05:45 PM |
| 350HP on 2ZZ-GE? | forpinks | Performance Modifications | 42 | 04-02-2007 11:01 AM |
