Old 03-28-2014, 01:53 PM   #1
jcboy
Drives: Sedan 07
good to hear. for future reference, this has always been my advice re car problems: do the cheapest/easiest one to replace among all the possible culprits. this is, of course, if the possible culprits haven't been narrowed down. (e.g. in your case you sustained front damage, so you don't have to follow the same order below)
in this example (overheating problems):
1) check for leaks
2) bleed radiator
3) replace radiator cap
4) replace thermoswitch (if present) as thermostats goes bad much more rarely
5) replace thermostat
6) replace water pump (and do the timing belt/tensioner bearings if it's not a yaris and uses a belt rather than a chain)
7) replace the radiator
8) head gasket replacement
Hope this helps.
Another case of Overheating Problem Slacky DIY / Maintenance / Service 5 01-24-2014 02:22 PM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
