Old 03-31-2014, 09:05 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
For the same power and way better fuel economy, the 2ZR is the far better option.
Old 03-31-2014, 09:33 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Personally I can't really understand why someone would even consider FE if they are going to go through the process of a full swap. THE 4E-FTE is lighter than the 2zr, has stronger rods, and a very nice compression ratio of 8.5:1. Also it has a lightened crank from the factory. This motor has the ability to easily get 38-44mpg on the highway in the Yaris paltform even om the higher boost setting for the internal wastegate. Around 32-35 in the city I bet too. Since it doesn't have all the other electronic BS required as the newer engines I have known guys that have bumped it to 1 bar of boost, kept their FE, and been around 165-175hp handily. Then if you wanted to get really into it you can get 260-300hp out od it without even changing the internals. You won't do that I don't believe with the 2zr.
From my m-o-b-i-l-e
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
