![]() Drives: scion xb Join Date: Nov 2013
I'm a believer in synthetic I have always used 5-30wt usually Mobil 1 or a generic brand synthetic oil. I've had several vehicles that when swapped to synthetic the operating temps dropped about 10 degrees..So that convinced me to stay on that path.
I've done the majority of my changes at between 5k and the longest was over 11k, I live 2 hrs east of Los Angeles and ITS HOT where I live. HOT as in 120 degrees!! in the summer and 2 months over 100 degrees EVERY DAY. I drive my little car ..quite hard, Im sure I drive the poor thing FAR harder than most people here probably anyone..I'm not to proud to admit that, but its probably true When I changed the oil at 11k..IT WAS DARK, PURE BLACK IMO it was FAR TOO LONG, I also run a stupid "oiled" INJEN CAI air filter most of the time..it doesn't filter anywhere near as well as a stock filter does so probably attributed to the extremely dirty oil..I'm totally in favor and recommend anyone to change the oil between 3k and 5k especially if you utilize a aftermarket "performance" I have 160,000 very hard miles and she's still running pretty good..no complaint. I do see metal particles in my oil changes. I might post another thread on this..I've been told its perfectly normal under any situation..so im on the fence over it. |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
I use to do it every 10 k. I do it 5.5 to 6.5 k now.
I am using Castrol high mileage oil for cars with 100 000 km and more.I change the oil filter and air filter every 6 months. Gearbox oil every 40k again using Castrol product called Syntrax with G70 gear box treatment additive. |
#3 | |
![]() ![]() Drives: 2008 Liftback Join Date: Nov 2010
I've never seen metal in my Yaris oil! I'd start a used oil analysis regimen on that car post haste before you get in position where the engine fails.
AMSOIL Synthetic Lubricants Direct Jobber |
#4 | |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Yaris XP9 diesel 90hp burning oil | bubu | DIY / Maintenance / Service | 3 | 12-04-2013 02:08 PM |
| Natural Gas Transportation - Why Not? | Kal-El | Off-topic / Other Cars / Everything else Discussions | 1 | 03-20-2011 01:12 PM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
