Old 04-26-2014, 06:44 PM   #1
Rigaud
Drives: 2009 Yaris
http://www.exhaustvideos.com/faq/exh...m-power-curve/
Check this out. According to these folks you should stick with stock diameter if you are making no other upgrades.
sent from my m-o-b-i-l-e
Exactly, you gain more from staying with stock size but going with mandrel bent pipes. Same with cold air intakes that usually only gives a faster throttle response but no real h.p. gains on small engines. Read alot of research and studies on it.
Old 04-29-2014, 12:14 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
how would the method of molding the metal effect performance?
Old 04-29-2014, 12:56 PM   #3
Rigaud
Drives: 2009 Yaris
look up mandrel bending. Pipes stay perfectly round in bends where as stock pipes are flattened and or rippled in the bends. Stock pipes have air flow restrictions due to that.
Straight pipe? FlushYaris Performance Modifications 29 04-28-2014 12:19 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Benefits of Removing Cat and Running Straight Pipe? Nexus1155 Performance Modifications 68 03-29-2012 01:00 AM
2.5' First Cat Straight Pipe with Greddy Ti-C gwasabi Performance Modifications 15 03-01-2009 10:50 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
