Old 05-20-2014, 06:53 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
looking for steel wheel to use as full size spare
and at this point it looks like the easiest thing to do is buy a steel wheel of tire rack for $50 w/ shipping.
I've tried some of the so called websites that search junkyards and some pick n pulls and found nothing. I've tried other websites like rockauto and found nothing.
the wheel size i would like is 14x5.5. Should I just get the yellow pages and start calling all the local junkyards?
Colin Chapman disciple
Old 05-20-2014, 08:59 PM   #2
Mongoose7
Drives: 2007 Yaris HB
You could ask the junk yards for an Echo 14"(2000 to 2005) ; or Corolla (1995 to 2002) 14"OEM wheels.
Mike
Mongoose7 is offline   Reply With Quote
Old 05-20-2014, 09:13 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Mike
echo wheel will not fit over yaris front calipers ...not sure on corolla .
Old 05-20-2014, 09:52 PM   #4
why?
why?'s Avatar
Drives: Yaris LB
are you sure? Now I would not try the 13" echo wheels, but the 14" are actually 5.5 inch wide, while the Yaris ones stock were only 5".
found one website that lists bore, http://www.wheelfitment.net/toyota of course it does not list the echo, however I would highly doubt the US Echo would come differently than the rest of the world Yaris.
Here is another one that seems to confirm it : http://www.wheel-fitment.com/car/Toyota/
Old 05-20-2014, 09:33 PM   #5
why?
why?'s Avatar
Drives: Yaris LB
Mike
that worked. thank you. Still nothing that close to me though, gah. Or maybe I need to learn that driving a bit is ok.
Old 05-20-2014, 09:45 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I have a set of 14x5.5 wheels from a 1993 Protege, no caliper clearance issues.
Old 05-20-2014, 10:18 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
The reason I say this is cos we had someone trade in an echo she had extra snows on rims stock and would not clear the calipers on her new Yaris ..offset is off just enuf to cause a problem . .was surprised too
Sent from my XT1032
Old 05-21-2014, 12:21 AM   #8
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Probably the same as Tire Rack when you get done with shipping!
http://akroncanton.craigslist.org/pts/4428651462.html
JTDBT903 is offline   Reply With Quote
Old 05-21-2014, 08:38 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
Sent from my XT1032
Most likely your someone had 13" wheels, which do not clear the Yaris calipers.
14" work without issues. When i sold my echo.. my steel winters were handed to my friend who just got a Yaris RS...
Old 05-21-2014, 05:59 AM   #10
bronsin
bronsin's Avatar
I got a wheel AND usable for a spare tire from a place in CA. Did the same for the wifes Camry. Dont remember how much but I did it so it must have been good.
The info is at home and Im at work. PM me if I dont get back to you.
Old 05-21-2014, 08:49 AM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Was a 14 maybe aftermarket rims ...
Sent from my XT1032
Old 05-21-2014, 09:26 PM   #12
why?
why?'s Avatar
Drives: Yaris LB
Sent from my XT1032
It is possible, as some 14" rims are really 13" rims in disguise, and if there is not enough clearance, offset, and backspacing they would not fit. Even my 14" wheels clear with very little room.
Old 05-21-2014, 11:52 PM   #13
IllusionX
Very possible. I know some miata rims won't fit.
Old 05-22-2014, 06:01 AM   #14
bronsin
bronsin's Avatar
Forgot to get the name of the place....
Old 05-22-2014, 12:03 PM   #15
Yaristeve
Drives: 3-door hatch
According to my owners' manual, a full size tire will not fit inside the spare tire well. That is why the rear seat backs have those straps. In the event of a flat, the flat tire is supposed to be strapped to the back of the rear seat back.
Or did you modify your hatch area somehow to allow a full size tire/wheel to fit?
Old 05-23-2014, 06:40 AM   #16
why?
why?'s Avatar
Drives: Yaris LB
http://www.yarisworld.com/forums/showthread.php?t=30847
Old 05-23-2014, 11:50 AM   #17
Yaristeve
Ah. I see room is not a problem...
Old 05-23-2014, 01:58 PM   #18
why?
why?'s Avatar
Drives: Yaris LB
Originally Posted by Rigaud View Post
I see no reason to require a full size wheel as a spare. The spare provided does the job. My 2 cents
To buy the oem spare tire in the correct size is the exact same price as to buy a full size spare. Gee, which would I purchase?
indeed.
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
FREE to good Yaris - Full size bed conversion Jonkey Australia 3 07-08-2013 12:40 PM
Full Moon wheel covers NJBob Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 06-11-2009 04:30 PM
My Avatar... Full Size Nutzoids Off-topic / Other Cars / Everything else Discussions 18 08-08-2007 11:51 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
