Old 05-21-2014, 05:13 PM   #1
j-san
Drives: 2010 5-door hatchback
A question for you exhaust gurus:
A search of the forum turns up conflicting reports of a freer-flowing aftermarket exhaust system improving/hurting MPG. Some said it improves MPG and power, others have said it hurts MPG, but improves power. Either way, it seems a better exhaust will improve power and possibly affect MPG.
I drive with a fairly light foot and mostly on the highway and average 43MPG most days. My Yaris is stock, but I am open to doing an aftermarket exhaust, provided it doesn't sound like bad rice and seriously hurt MPG. I wouldn't mind the few extra HP for a little help in the passing lane. If I go aftermarket, I plan to leave the intake stock and drop in a K&N filter. Maybe a header is fine, but I plan to leave the cats and resonator intact and possibly add an additional resonator after the stock one. There is a local custom exhaust shop that can do the work and I would ask them to follow the stock piping, but go up to a 2" pipe vs the stock 1.75" pipe (I understand the cats and resonator use a 2" pipe) and route it to the factory flange at the rear axle. From there, I'll probably bolt on a Tanabe Medalion or Nitto (plan to buy from Micro Image) as those two seem to be the quietest mufflers. How does that sound for an exhaust set-up?
I am not expecting oh-my-god gains in HP or anything, but hope to have a little of both worlds: improved HP while being able to retain (or improve) MPG.
j-san is offline   Reply With Quote
Old 05-22-2014, 09:35 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
To be honest. Keep the stock exhaust for mpg. I usually have run about 3mpg less with my exhausts. Most of the fact that I love to listen to my exhaust. Plus the stock exhaust is better matched for low rpm performance.
A typical muffler shop will only crush-bend tubing. So their 2" tubing is typically smaller in the bends then your stock midpipe. So the only thing your getting is no improvement in exhaust flow and lower quality tubing that will rust out eventually.
I suggest a rear section exhaust for some power and sound and not throwing away all your mpg.
These motors really love a full exhaust so real gains in power can be realized
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-23-2014, 09:04 AM   #3
j-san
Thanks much for the advice. I may just look into getting a axle-back system like the Tanabe Medalion and leave the rest stock. Maybe have the shop weld in another resonator if I find the aftermarket muffler too noisy.
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 10:13 PM
Why is DTM exhaust thread closed? gr8yaris Performance Modifications 4 01-13-2007 11:01 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
Toyota Performance Exhaust for Yaris HB bigsky2 Performance Modifications 16 06-02-2006 10:21 AM
