Only Happy When it Rains
looking for steel wheel to use as full size spare
and at this point it looks like the easiest thing to do is buy a steel wheel of tire rack for $50 w/ shipping.
I've tried some of the so called websites that search junkyards and some pick n pulls and found nothing. I've tried other websites like rockauto and found nothing. the wheel size i would like is 14x5.5. Should I just get the yellow pages and start calling all the local junkyards?
Colin Chapman disciple |
![]() ![]() Drives: 2007 Yaris HB Join Date: Mar 2012
You could ask the junk yards for an Echo 14"(2000 to 2005) ; or Corolla (1995 to 2002) 14"OEM wheels.
Mike |
that worked. thank you. Still nothing that close to me though, gah. Or maybe I need to learn that driving a bit is ok.
2ZR swap. DO IT! Ask how!
I have a set of 14x5.5 wheels from a 1993 Protege, no caliper clearance issues.
#6 | |
found one website that lists bore, http://www.wheelfitment.net/toyota of course it does not list the echo, however I would highly doubt the US Echo would come differently than the rest of the world Yaris. Here is another one that seems to confirm it : http://www.wheel-fitment.com/car/Toyota/
Colin Chapman disciple Last edited by why?; 05-20-2014 at 10:15 PM. |
The reason I say this is cos we had someone trade in an echo she had extra snows on rims stock and would not clear the calipers on her new Yaris ..offset is off just enuf to cause a problem . .was surprised too
Sent from my XT1032 |
![]() ![]() Drives: '08 SEDAN 5 SPD. Join Date: Aug 2009
Probably the same as Tire Rack when you get done with shipping!
http://akroncanton.craigslist.org/pts/4428651462.html
I got a wheel AND usable for a spare tire from a place in CA. Did the same for the wifes Camry. Dont remember how much but I did it so it must have been good.
The info is at home and Im at work. PM me if I dont get back to you.
#10 | ||
14" work without issues. When i sold my echo.. my steel winters were handed to my friend who just got a Yaris RS... |
Was a 14 maybe aftermarket rims ...
It is possible, as some 14" rims are really 13" rims in disguise, and if there is not enough clearance, offset, and backspacing they would not fit. Even my 14" wheels clear with very little room.
Very possible. I know some miata rims won't fit.
#14 |
Forgot to get the name of the place....
#15 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Or did you modify your hatch area somehow to allow a full size tire/wheel to fit? |
#16 | |
#17 |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
I see no reason to require a full size wheel as a spare. The spare provided does the job. My 2 cents
#18 |
^ It's just safer to use a full size spare if you are not running on stock size tires. At least, i find so.
Either way, if i get a flat up front, i don't install the spare in the front.. I'd put it in the rear and then put the rear tire up front. |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| FREE to good Yaris - Full size bed conversion | Jonkey | Australia | 3 | 07-08-2013 12:40 PM |
| Full Moon wheel covers | NJBob | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 06-11-2009 04:30 PM |
| My Avatar... Full Size | Nutzoids | Off-topic / Other Cars / Everything else Discussions | 18 | 08-08-2007 11:51 AM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
