![]() Drives: Toyota Yaris D-4D 2008 Join Date: Oct 2013
Hi guys,
I've been looking around the "wheel, tire and suspension" area for some time and noticed that a lot in 17 inch rims are using 205/40/17 tires. I want to replace my current wheels setup (Japan Racing JR-8 15x6.5J ET+38 with 185/60/15 tires on my yaris bizz D-4D) to 205/45/17 with some 17x7.5J ET+40 offset rims. I was wondering if I will be able to drop this using Tein S-Tech Springs (approx 1.9 inch drop) on stock shocks without having rubbing issues? ![]() (ON FUTURE I´M PLANNING TO MOUNT TOKICO BLUES SHOCKS) ![]() Hope you could give me advice. Please, if you could post pictures of your cars with the same setup as i want, would be great Thanks! Last edited by JFRANSSA; 04-10-2014 at 07:05 AM. |
bump
2ZR swap. DO IT! Ask how!
According to the size comparison widget at rimsntires.com, you've got enough room. I have 205/50R15 BFG Rivals on 15x7 ET 42 for my race tires, as well as MI springs with Tokico blues. I get wheel rub against the frame near steering lock, and fender rub on hard cornering. The rears have plenty of room. Tien S-techs have slightly more drop, so you may have more issues during normal driving. My solution for the fender rub was to install -1.5° OEM crash (camber) bolts.
I think it may just be a "try it and see if it works" fitment. |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
205/45/17 = 24.3*
205/40/17 = 23.5* (Most lowered applications) 215/40/17 = 23.8 http://www.yarisworld.com/forums/showthread.php?t=5021 |
No one else can give me your opinion?
![]() I've done the test fit with 205/40R17'' and 205/45R17'', was leaning size 205/45R17'' but I'm afraid of having problems with scraping the fenders. what advise me? will i have ploblems with 205/45R17''? ![]() here is a picture with the 205/40R17'' ![]() ![]() here is a picture with the 205/45R17'' ![]() ![]()
Form>Function
That's your car??
I think you should be fine. You may rub on large bumps or with people in the back, worst comes to worst you can just lightly roll your inner fender lips, wont do anything to the body on the outside and will alleviate any rubbing. Looks good though. |
#7 | |
![]() So in your opinion i can ride with 205/45R17 right? ![]() My problem is on the front fenders because on the rear i have enough space and i don't have rear seats because this car is a business car so only have the two front seats dude
Form>Function
oh yea that solves any problem in the rear lol. I think you will be fine up front, if not like i said you can use your hands and slightly pull on the fender and it will clear
we had a friend rocking 205/45R17 before and the fender liner/cover inside created a hole due to the tires rubbing inside. Phil is right about fender rolling, but you should watch out for the fender lining as well.
Just my .02 cents. |
Form>Function
The liner is nothing, its a thin piece of plastic it wont do any damage to your tires
![]() ![]() ![]() Drives: Yaris sedan Join Date: Jan 2009
I'm on 2" lowering springs.
Here is a pic when I had 17" Hated the feeling with big rims :/
Thanks Phil :-)
I will try but you re right, if i rub will be on the piece of plastic ![]() Enviado do meu GT-P7320 através de Tapatalk |
#15 | |
Pros- Looked great :/
Form>Function
anytime man, glad I could help.
May I steal the thread since it's about tein s-tech springs and rims.
I have tein s-tech springs with Enkei 15x7 ET 35. I'm wondering will 195/55/15 rub ? I know that 195/50/15 are fine however I feel they're low profile and will make the ride very hard so I prefer 195/55. Thanks |
im on 195 55 15 42 offset and 1.8 drop ...i really dont see a problem with given offset and drop.
| want 2 lower with tein but have tyre rub HELP! | MR. CANTON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-24-2007 05:16 PM |
| Tein Springs | nickhjort | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 08-15-2007 01:33 AM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 10:22 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 06:08 PM |
| planning to lower my car | thegame11 | Cosmetic Modifications (Exterior/Interior) | 7 | 03-18-2007 12:49 PM |
