Old 05-28-2014, 01:32 PM   #8
esse10
Drives: 2009 yaris 2 door
remove
I would remove (50k miles), inspect , check the gap and put back in with anti-seize on the threads for easy removal next time. That's 50,000 us miles. torque? is usually skill of the craft but if you want to be specific it's usually around 20-25 footpounds, and no the value does not change with anti-seize on the threads. 20 foot pounds of pressure is still 20 foot pounds of pressure no matter if the threads have a lubricant on them, it'll slide in a little farther with the lubricant on but not to make a difference, 20 pounds is still 20 pounds. if you had a soft alloy metal that would bend or something I would say yes torque them less if the threads had lubricant, I don't think in this case.
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
