Old 02-10-2014, 12:33 PM   #37
Originally Posted by jazzyb88 View Post
Thanks CTScott! :)
Interesting there is wiring for a phone mic...I wonder where that is supposed to be mounted? This makes me think that there is probably wiring present for rear speakers (I have a 3dr UK spec, which did not have rears). Might be a project for another time!
The four pins in the white connector to the left of the blue one says that you do have wiring for the rear speakers (or at least from the radio to a junction connector).
Old 02-10-2014, 04:54 PM   #38
jazzyb88
Drives: 2009 Hatchback
Thanks
jazzyb88 is offline   Reply With Quote
Old 04-09-2014, 07:27 PM   #39
tigobrata
Drives: toyota yaris
Hello, everyone, i just bought a toyota yaris 1.0 from 2007, and let me say, this post is a dream for anyone who just bought this car haha, i just have one small question if i may
in the radio wiring, in the cn700 conector, can anyone explain the function of pins 1 (CSLD-GND), 9 (TXM+), 10 (TXM-), 11 (ACC+B, i believe this has to do with the ignition no?) and finally 12 (BU+B)?
Thank you so much in advance, and again, great tips thus far :D
tigobrata is offline   Reply With Quote
Old 04-09-2014, 09:58 PM   #40
CSLD-GND is a ground for the CD Changer communications.
TXM+ and TXM- are data communications lines for the CD changer.
ACC +B is accessory switched power
BU +B is constant power
Old 05-29-2014, 05:09 PM   #41
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
ok I`m blond or stupid... or both... I can read and I can search but I am unable to understand this...!!! is there a grafic somewhere with the plug wirh numbers and a list of what wire does what? yea I know it's sound weird but I just don't want to plug it wrong :(
the_boss is offline   Reply With Quote
Old 05-29-2014, 05:17 PM   #42
Kind of - The electrical wiring diagrams section of the service manual would be about the closest to that.
Old 05-29-2014, 05:24 PM   #43
the_boss
the_boss's Avatar
I wish I could find it easily!
Thanks!
Old 06-06-2023, 03:12 PM   #44
JJ del Castillo
Drives: Yaris 2008
Disconnected stereo and alarm dosesn´t works
Hi!! thank´s for the info!!, at some point you said that :
Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
The only thing that I did is taking off the OEM stereo, unplugged the harnesses, and then the alarm doesen´t works...any help? the car stereo has tree different harnesses at back, but I want to replace it with a new one.
Do I need a new alarm?
Thank´s a lot!!!
Originally Posted by battleversiontc View Post
this should be a sticky 2007-2008 might be same for 2009 not to sure
12volts yellow (25A), gray (15A) + ignition harness
Starter black (x2)(common) + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition green + ignition harness
Third Ignition N/A
Accessory white + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock brown - driver kick, 20 pin plug, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow to green (double pulse) - driver kick, 20 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15.
Lock Motor white to orange 5wi driver kick, 20 pin plug, pin 10
Unlock Motor lt. blue to pink 5wi driver kick, 20 pin plug, pin 20
Parking Lights+ green + fuse box, top L, 30 pin plug, pin 29
Parking Lights- white - headlight switch
Notes: Not available on all models.
Hazards black - hazard light switch
Turn Signal(L) lt. green + fuse box, top L, 30 pin plug, pin 27
Turn Signal(R) yellow + fuse box, top L, 30 pin plug, pin 28
Reverse Light red + fuse box, top L, 30 pin plug, pin 30
Door Trigger see notes - fuse box, top left, 30 pin plug
Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each.
Dome Supervision pink - fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pin lt. blue - fuse box, top L, 30 pin plug, pin 7
Hood Pin white - pin sw or theft warning ECU, pin 4
Notes: The theft warning ECU is behind the glovebox.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer lt. green ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire green to purple + fuse box, top L, 30 pin plug, pin 12
Parking Brake yellow - fuse box, top R, 16 pin plug, pin 2
Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Headlight lt. blue - headlight switch
Speed Sense purple fuse box, top, 36 pin plug, pin 26
Wipers blue (L), yellow (H) + windshield wiper switch
LF Window up/dn red - green A driver window switch in door
RF Window up/dn white - pink A driver kick, 18 pin plg, pins 11, 10
LR Window up/dn yellow - black A driver kick, 18 pin plug, pins 8, 9
RR Window up/dn red - green A driver kick, 18 pin plg, pins 17, 18
Radio 12v blue + radio harness
Radio Ground white/black - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna black + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- gray - yellow +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
JJ del Castillo is offline   Reply With Quote
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 03:02 AM
Factory wire harness or plastic aftermarket piece for aftermarket radio????? Yarisguy13 Great Lakes 1 09-17-2007 11:14 AM
Keyless Entry Wire Colors? Kaeon In Car Entertainment + Electronics (audio / video / alarm) 0 09-16-2007 03:39 PM
Radio Wire Diagram????? Yarisguy13 General Yaris / Vitz Discussion 1 04-18-2007 11:58 PM
