Old 05-29-2014, 04:28 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
yeah... the same facelift is going to happen for NA market.
Old 05-29-2014, 05:34 PM   #2
nookandcrannycar
I hope not re the U.S.....the press release (on the other thread.....not the European one linked to post #1 on this thread) only mentions the Canadian market.
Old 05-29-2014, 05:51 PM   #3
roxy1
Drives: 2014 yaris 5 speed
I would like to see the 6 speed manual...if it is done with fuel efficiency in mind. if its just going to mean closer ratios but the same final gear with the same rpms at cruising speed then it wont really mean much for this car with this engine (except more shifting). however, if it gives the yaris a higher cruising gear, some highway mpg's should be gained.
the largemouth bass grill I could do without. its been a trend for the last several years for all manufacturers, so there is no fighting it.
roxy1 is offline   Reply With Quote
Old 05-29-2014, 06:03 PM   #4
nookandcrannycar
I would too....but not enough to have to look at that grille....and clean the bugs off of it .
Old 05-29-2014, 06:00 PM   #5
nookandcrannycar
^^^^^ Actually, I just reread the press release and it does make one reference to 84% of 2014 model year production from the plant in France going to the U.S., Canada, and Puerto Rico. However, whenever I have checked the VIN# on inventory, the VIN# has indicated that the car came from Japan (every time). If any U.S. YW member with a 2014 has posted that their car came from France, I've miss seeing such a post.
Old 05-30-2014, 08:15 AM   #6
IllusionX
If you don't want the new model, the Yaris is probably going to be discontinued altogether in the US.
Old 05-30-2014, 11:10 AM   #7
roxy1
based on what?
the yaris being built alongside the mazda in mexico makes it even more likely it will continue in the U.S.
Old 05-30-2014, 11:46 AM   #8
IllusionX
based on what?
Base on nothing. Just an assumption. I still don't know understand why so much hate on a facelift.
Toyota recalling 1.53 million cars globally fnkngrv Off-topic / Other Cars / Everything else Discussions 2 10-21-2010 02:26 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
