Old 06-03-2014, 10:34 PM   #1
jess
Drives: 09 hatchback
You can't go wrong
2009 with 187k miles. Looks like new. Regular oil changes, one new battery, one trans fluid and coolant change and a new set of tires (dealer Bridgestone were good for 150k miles!) That's it!! Just got back from brake check. No need for new pads. Still using original pads. Still getting 40 mpg!!
jess is offline   Reply With Quote
Old 06-03-2014, 10:55 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
original brakes at 187k miles i find that hard to believe
Old 06-03-2014, 11:27 PM   #3
nookandcrannycar
I still have my original brakes at almost 282k miles. I just had my brakes checked in February....many more miles of life left. IIRC, my pads were under 40% worn at 208k miles (actual figure is on Kal-El's mileage thread). Yarisworld member trini_per4mance (an original owner who has more than 500k miles on his Yaris) didn't have to do any brake work at all on his Yaris until 400k miles.
Old 06-03-2014, 10:57 PM   #4
nookandcrannycar
I agree, you can't go wrong. Other than what you've had by 187k I (by that mileage) also had an alternator and front wheel bearings, and a few bulbs....not much since except 2 batteries in this heat. = amazing re your tires. Mine have been 70,000-85,000 per set.
Old 06-04-2014, 06:17 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
Highway miles don't need ally of brake.
Old 06-04-2014, 11:10 AM   #6
nookandcrannycar
Re my Yaris, my miles are a good mixture of highway and surface streets with signals or stop signs. I think the main reason in my case is that I drive my Yaris pretty gently. With Trini (judging from his previous You Tube videos), I think you're right. He doesn't drive gently, but drove a ton of highway miles when he was racking up the miles quickly on his Yaris.
Old 06-04-2014, 12:26 PM   #7
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
if you hypermile you hardly ever use brakes. just sayin.
trunkout is offline   Reply With Quote
Old 06-04-2014, 06:50 PM   #8
nookandcrannycar
Yeah, my driving style is somewhat that of a hypermiler, but my maintenance gaps re some things (spark plugs, oil changes, air filter changes, etc) and ignoring others (throttle body, MAF, etc.) probably keep me from getting consistent 'hypermiler results'.
Old 06-04-2014, 12:49 PM   #9
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
It is amazing how long Toyota Yaris parts can go before needing replacement.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 06-05-2014, 12:25 AM   #10
jess
Just remembered I replaced air filter once (cleaned old one a few times) and yeah its ben mostly highway miles. But up and down California coast and meandering the Sierras is full of braking. The mechanics at the shop were also shocked at the original brakes.
Hypermiling rules!
Is it wrong to max out a Steering? dante2086 DIY / Maintenance / Service 13 09-17-2010 02:56 PM
Wrong Fitment Yaris Kaotic Lazagna California 2 08-04-2009 01:12 AM
Whats wrong with Rota's? mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 172 05-22-2009 11:13 AM
Will this work or I got the wrong harness? TDL In Car Entertainment + Electronics (audio / video / alarm) 2 04-19-2007 02:26 PM
