HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
The XD output shaft and ring gear are different to the Yaris, they are larger you can"t drop a Yaris diff into XD tranny also one thing to look at is that the XD output shaft bearing is wider its the one that is next to the DIff so I don"t know if it cahnges the case or if it's just a different bearing.
R-CaT Project Yar 2ZR |
#2 | |
2ZR swap. DO IT! Ask how!
My C56 and C59 have the same pinion bearing setup: the inner bearing race is held on the pinion shaft, so the bearing in the housing has a larger center opening with multiple smaller rollers. The Yaris/xB both use the shaft itself as the inner race and have a smaller center with fewer larger rollers. My camera battery is dead, otherwise I'd take pictures to show the difference. I'll see what I can do over the weekend for some pictures. |
#3 | |
HacKers WanTed!
The pinion shaft of the XD is the same of the C56 & C59 thats way it uses the larger diff and I was able to source the Helical. The Xd is more like a corolla tranny than a yaris tranny. I'm really bad at explaining things I'm the type that talks pointing at stuff with my finger, like that there and this over there.
#4 | |
#5 | |
The output/pinion shaft bearing has the same OD, it's just a different ID. Easy to swap with a blind bearing puller. As far as overall dimensions go, the Matrix and Celica differentials seemed to fit just fine--the axial length between the taper bearings looks to be identical. Last edited by CrankyOldMan; 09-11-2014 at 06:44 AM. |
#6 | |
0-60 in slow
Jason you might want to look for the TRD 41201-NP100 final drive.
I believe the older AW11 MR2 and Celicas with the 4A-Fe engines used that final drive(4.058). Its a C52 so I'd imagine it would work. |
The TRD set has been listed as discontinued for years... Certainly its possible there is one out there, but good luck tracking it down.
![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
hello ,sorry to bother you guys but i have been successful in using the c60 celica gears in my yaris c50 ,i could only use gears three , four and five ,the shaft of the c 60 is the same as the c50 except it is a little longer (for sixth gear ) , i also used a 4.31 off a first gen xb. I have also swaped internals out of a 09 corolla c59 into a xd case to get 4.31 final and a closer 1st and 2nd gear. i didn't want to cut the frame to get a c60.
| changing gear from robotic to automatic | mariann | DIY / Maintenance / Service | 13 | 12-09-2011 06:43 PM |
| Gear Ratios | J_T | Performance Modifications | 1 | 06-16-2011 12:31 AM |
| Changing Gear Oil Of the C160 | Parmas | DIY / Maintenance / Service | 12 | 01-20-2011 02:44 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| Gear Ratios? | aephilli | DIY / Maintenance / Service | 3 | 04-12-2007 05:38 PM |
