#11 | |
2ZR swap. DO IT! Ask how!
The output/pinion shaft bearing has the same OD, it's just a different ID. Easy to swap with a blind bearing puller. As far as overall dimensions go, the Matrix and Celica differentials seemed to fit just fine--the axial length between the taper bearings looks to be identical. Last edited by CrankyOldMan; 09-11-2014 at 06:44 AM. |
| changing gear from robotic to automatic | mariann | DIY / Maintenance / Service | 13 | 12-09-2011 06:43 PM |
| Gear Ratios | J_T | Performance Modifications | 1 | 06-16-2011 12:31 AM |
| Changing Gear Oil Of the C160 | Parmas | DIY / Maintenance / Service | 12 | 01-20-2011 02:44 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| Gear Ratios? | aephilli | DIY / Maintenance / Service | 3 | 04-12-2007 05:38 PM |
