Old 07-18-2014, 06:15 AM   #20
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by RagnaCaT View Post
ok let me see if I get it FD is 68 x 18 for the yaris 3.77 and 67 x 17 is 3.94 ??? I remeber we counted the Yaris teeth and the both had 67 x 17 only that the XD ring gear was taller I might be wrong
Yes, that's the right idea. I think you may need to count the Yaris again though, it should be 67:18 = 3.722. By "taller" do you mean the thickness of the gear, or taller/shorter gear ratio?
changing gear from robotic to automatic mariann DIY / Maintenance / Service 13 12-09-2011 06:43 PM
Gear Ratios J_T Performance Modifications 1 06-16-2011 12:31 AM
Changing Gear Oil Of the C160 Parmas DIY / Maintenance / Service 12 01-20-2011 02:44 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Gear Ratios? aephilli DIY / Maintenance / Service 3 04-12-2007 05:38 PM
