HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
Taller is that the ring gear side by side the XD is taller than the Yaris ring gear
R-CaT Project Yar 2ZR |
2ZR swap. DO IT! Ask how!
Oh, yes, I noticed that too. If you just put the diff and pinion shaft in, they will scrape against each other. If you install the center housing and put the retaining clip on the bearing, it lifts the pinion shaft up a few mm, which should give plenty of clearance.
#3 | |
HacKers WanTed!
I'm not sure I understand what you're asking for. The difference in gear ratios, the difference between part numbers for identical rations, or something else?
| changing gear from robotic to automatic | mariann | DIY / Maintenance / Service | 13 | 12-09-2011 06:43 PM |
| Gear Ratios | J_T | Performance Modifications | 1 | 06-16-2011 12:31 AM |
| Changing Gear Oil Of the C160 | Parmas | DIY / Maintenance / Service | 12 | 01-20-2011 02:44 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| Gear Ratios? | aephilli | DIY / Maintenance / Service | 3 | 04-12-2007 05:38 PM |
