Old 07-19-2014, 01:27 PM   #1
bronsin
bronsin's Avatar
Theres quite a bit more oil than that, maybe another 5 or 6 quarts, which is in the torque converter and cant be changed by removing the oil pan.
Because there is so much oil and because there are no combustion by products as there are in an internal combustion engine its probably not necessary to change the oil in an automatic transmission under typical operating conditions..
The 2000 ECHO I bought for my son racked up ~200k miles when we sold it and its transmission oil was never changed. The trans and engine ran normally when we sold it.
Old 07-19-2014, 04:20 PM   #2
UberSilver
UberSilver's Avatar
Not a 100% true. After I changed the trans filter, I no longer had a rough idle. It would seem that a dirty filter raised the hydraulic pressure (or pump load)enough to increase the load on the engine, causing a rough idle.
Had a small but noticeable increase in mpg as well.
So will a Toyota run till 200K miles with out a fluid change? Yes. Will it run better with fluid changes? Very much Yes!
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Transmission fluid level Twistoffate0817 DIY / Maintenance / Service 2 11-28-2012 05:15 PM
changing transmission fluid (automatic) caineroad General Yaris / Vitz Discussion 4 07-18-2012 01:35 PM
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
