![]() Drives: Yaris Join Date: Mar 2013
Thank you Scott for info and the pic.
Very helpful! I think I'll take this one on myself. Thank you Alphadriver |
#2 | |
bolt size is 14 mm, ur in Boston so u have winter and snow i just did mine on 07 and had to use torch to brake bolts loose also a bolt extractor cos the bolts when corroded shrink hard to grab on with socket ...also if they brake ur in for lots of extra work, if u get parts get gasket and bolts with new springs. I do recommend heat the nut side or they may brake . just my 2 cents |
Thank you for your input as well wolf man!
shop should charge no more than half hr work plus parts with proper tools it makes the job easier ...i did it at my shop and with the problems i encountered was just over 30 min working on a hoist under the car makes life easier.
| DC Sports Header install and evaluation | Loren | Performance Modifications | 217 | 07-04-2017 06:40 AM |
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Like KYB OEM Front Struts w/pics $70. Also Stock Exhaust and springs | bronzebullet232 | Items for Sale by private party | 3 | 01-27-2010 10:11 PM |
| Improved Factory Exhuast Pipe for '08 Liftback | TheSilkySmooth | DIY / Maintenance / Service | 10 | 11-10-2009 08:36 AM |
