Old 07-27-2014, 02:00 PM   #1
brake discs keep 'warping'
The practice of bedding is something I fail to fully comprehend. Surely any garage performing brake work does not bother with such measures. It would seem to me that such measures are only performed by the most diligent of gear heads.
Old 07-27-2014, 02:04 PM   #2
In the old days of good ol' asbestos it wasn't really necessary, but with the modern semi-metallic pads it really is if you do a lot of hard braking. If you are always gentle with the brake pedal, then you will never really notice the build-up occur.
For the original poster, I suspect that it is either the quality of the replacement discs and pads, or just a case where you drive in such a way that you really heat them up and warp them quickly.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Loose brake discs Garioch DIY / Maintenance / Service 4 03-07-2007 09:44 AM
