Old 07-27-2014, 06:30 PM   #1
Originally Posted by yaris9876 View Post
I see how it works now... but on mine the white plastic thing wont go in the unlock position.
I can leave it unlocked and lock it but the key just cant force it over to unlock
.... I lubed it well with wd40 but
still wont go... Would it be a big deal to replace the whole key drum and plastic thing with an aftermarket assembly that would fit in there??The drum seems to be held in my 2 bolts..not 1
You can replace it, but unless you have a locksmith modify the existing one you will need a separate key for the hatch. I have a couple of spare ones if you need one, as I changed two of mine over to using the Scion IQ hatch knob with switch and have it electrically actuated:
http://www.yarisworld.com/forums/showthread.php?t=39677
Also, try a different key, if you have a spare, as it may be that your key has worn too much for the hatch lock.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
3 door vs 5 door hatch bentjazz General Yaris / Vitz Discussion 48 03-13-2014 05:17 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
rear hatch for 08 yaris 5 door nb85351 Willing to Buy by private party 1 09-05-2010 07:12 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
