#37 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Hey Bike - does that wiring kit help smooth out the engine- My sisters 3 dr is like Jekl and Hyde - some days smooth and other it wont get out of its =way and runs like there is spark scatter or some 'puter problem real buzzy and no pull. Whats up with that?
- S's Bro |
#38 |
The ground kit made a big difference in the stereo system. It has no hums or buzzes at all. As for the performance, I've never had any problems with sputters. My plugs fire smooth all the time, even in the morning when it's cold. Don't know if it's related to the ground kit.... By the way, your avatar is looks like a heartbreaker !!
#39 |
aka Jack Wolfskin
#40 |
Parallel Parking Pro
Race/rally cars drive in tougher terrain and higher speeds than road cars, with upgraded suspension bushings, harder and/or longer travel suspension with grippy soft-compound tires that impose more stress on the chassis.
You don't need it for the local grocery shop special stage.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#41 | |
aka Jack Wolfskin
So the tower bar is a good addition to the chassis of the Yaris, not all of the above but also for the "sporty driver". |
#42 |
Who said Yaris was slow?
Is not that the front strut bars don't do nothing... they just don't do nothing on a Yaris...
This is due to the chasis configuration of the Yaris. Even if you are driving at the track... You will have to install a full racing suspension in order to receive any benefit from a this bar on the Yaris. There are a lot of other car that can use the benefit of a front strut bar even for street use. The Yaris is not one of those. On the other side the rear sway bar does alot for the car. I have not use the other under bracing available for the car... so I can not talk about those. |
#43 | |
#44 | |
#45 |
aka Jack Wolfskin
#46 |
![]() ![]() Drives: Jbody Join Date: Oct 2008
Nice addition under the hood!
#47 |
![]() ![]() ![]() ![]() Drives: Soon to be LFA Join Date: Oct 2008
very nice i want one so bad
#48 | |
![]() ![]() Drives: 07' HB Black Join Date: Nov 2008
When life passes you by ... dowshift
#49 |
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
Would the yaris benefit from a 3-point front strut bar?
If so, why has one not been developed yet? |
#50 |
I noticed a difference with mine. Especially on hard turns or really quick lane changes. Also was able to install mine without lifting car up but was really cramped fitting hand up there.
#51 |
![]() ![]() Drives: vitz rs Join Date: Apr 2011
They go shopping using front bar.
They go driving using rear. |
#52 |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
Just finished installing mine. Nice product with nice fittings and hardware. Simple install. Felt a difference in steering input and it seems as if it let's you enter harder into corners and allows some room for mistakes. Not a huge difference though. Probably would have passed on it and put the money towards getting Garms intake manifold. Definitely looks good though.
#53 |
Looks good!
#54 | |
![]() ![]() Drives: 06' Yaris 1.3l Join Date: Jul 2014
I'm thinking of getting one but not unsure on how to install. would you mind briefly doing over the details? Thanks |
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
| **NEW ITEM** Tanabe Sustec Front strut bars | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 04-27-2007 09:54 PM |
