Old 08-23-2014, 07:28 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Your maf housing is the incorrect diameter. If its any different then stock the readings are skewed.
At least on our 1.5s the maf housing is 60mm-2 3/8" Yours is probably the same. Larger will run lean...smaller will run rich
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-23-2014, 05:39 PM   #2
268i
Drives: 06' Yaris 1.3l
Oh, my MAF housing is 3"
But what I don't get is doesn't the ECU adapt to the difference in air flow etc over time.. (I have a fried also with 3" setup. )
Also, why does the engine shut off? AFAIK it should go into "Limp" mode..
268i is offline   Reply With Quote
