Old 08-26-2014, 10:02 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by nookandcrannycar View Post
I can see multiple future uses (for me) re what Scott has pulled together . However, I think your solution is ALSO great for a temporary need in California (use both) ......but I only need one of them...not eight . Do you know of any retail STORE (that has a location in TX, NM, AZ or CA...or even in Las Vegas) that sells them individually, not by the 8 pack ?
Oh, that's just the first pic I found of it. I bought mine at a local hardware store a few years back, so I don't know if it's even in production anymore.
Old 08-26-2014, 10:16 PM   #2
nookandcrannycar
Thanks. It is, I just haven't located anything smaller than an eight pack. I'll check a few stores in California when the time comes.
Old 08-27-2014, 03:48 AM   #3
Astroman
Modded Moderator
Astroman's Avatar
Nice cans you got there
Old 09-05-2014, 02:13 PM   #4
And, here's another advantage of using the Yaris in place of the Tacoma: FREE dump runs.
I pulled out a set of built-in bookshelves recently and needed to dispose of them. I decided to load them into the back of the Yaris, rather than using the carrier, as it was a lot of pieces of wood. We get charged by volume to dispose of items other than recyclables or household trash at our recycling center, and normally a run like this would run somewhere between $25 and $40 depending on which dump dude looked at the truck and estimated the volume. With my short bed Tacoma, this would have looked like a lot of material, so chances are that I would have gotten dinged the $40.
With the Yaris, I tell the dump dude that I have a book shelf in the back to dispose of and he looks at the car and says "In the back of that little thing?". I say yes and he says "It can't be very big to fit in there. No charge". Little did he realize that this is what was back there:
Old 09-06-2014, 08:22 AM   #5
bronsin
bronsin's Avatar
We get charged by volume to dispose of items other than recyclables or household trash at our recycling center, and normally a run like this would run somewhere between $25 and $40 depending on which dump dude looked at the truck and estimated the volume. Attachment 54039
$40 TO THROW SOMETHING OUT!!!!
First they cut peoples heads off on TV and now THIS!
(could this be the doing of the terrorists?)
Old 09-06-2014, 08:30 AM   #6
I think you may be right. They even charge to dispose of brush (which they then run through a chipper and sell as mulch).
Old 09-06-2014, 10:06 AM   #7
nookandcrannycar
The one I'll be dealing with in California charges $22.00 per cubic yard (with a minimum charge of $25.00 ) or between $78.00 and $83.75 per ton depending on the nature of the contents. Also set higher amounts for stoves, A/C units, TVs, CRTs, etc (at least they take TVs ). In 2009, it was a flat amount for access (a bit over $20.00)....at least for cars up to a Tundra sized pickup.
Old 09-16-2014, 12:14 PM   #8
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Oh, that is too sweet!
I once carried a futon in the back of my liftback. I taco'd the mattress and tied it that way. all seats folded down. Got the job done
Thanks for sharing this. I've been trying to decide between the two style hitch receivers for some time. I'll likely get one early next month.
carrier, hitch
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
How to turn ON Yaris Maintenance Required light? JohnnyRockets DIY / Maintenance / Service 11 12-14-2012 10:36 AM
Ohio Yarii owners: Turn in Concepts needs a Yaris to measure! schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-17-2009 04:20 PM
