Rear drum needs cleanup and lube. I have it on mine and it will always come back. :(
#2 | |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
+1 Take off the rear drums.. Brakleen everything. Use a flat head screwdriver to pry the shoes away from the backing plate about 1 cm.. Notice 6 hot spots per drum, three per shoe. They can be seen on the backing plate when the shoe is lifted. That's where your noise is probably coming from. Brakleen those. Lube them up with something. I used white lithium grease. Make sure no grease or lube gets on the braking surface! Enjoy your newly quiet brake pedal! Sent from my iPhone using Tapatalk |
Thank for your responses. However, this sounds like it is coming from inside under the dash at the peddle area. I also get that rear brake squeak your are referring to and that is under control...for now.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
