Old 09-27-2014, 02:22 PM   #2
bronsin
bronsin's Avatar
First off I believe you rounded off a NUT not a BOLT. I might be wrong.
Can you check that?
Thanks!
To remove a rounded nut or bolt you need a special wrench or socket made by Snap On. These tools drive on the flat of the nut or bolt not the corners as ordinary tools do.
Perhaps you can borrow one from a local shop in 12mm.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Is every 24,000 miles correct for replacing serp belt? JerseyJeff84 DIY / Maintenance / Service 11 09-09-2011 06:35 AM
Need help replacing acessory drive belt!!! stevebo DIY / Maintenance / Service 13 04-07-2011 02:57 PM
