First off I believe you rounded off a NUT not a BOLT. I might be wrong.
Can you check that? Thanks! To remove a rounded nut or bolt you need a special wrench or socket made by Snap On. These tools drive on the flat of the nut or bolt not the corners as ordinary tools do. Perhaps you can borrow one from a local shop in 12mm.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 10:41 AM |
| Is every 24,000 miles correct for replacing serp belt? | JerseyJeff84 | DIY / Maintenance / Service | 11 | 09-09-2011 06:35 AM |
| Need help replacing acessory drive belt!!! | stevebo | DIY / Maintenance / Service | 13 | 04-07-2011 02:57 PM |
