Ok i see what you are trying to say.
Driver side is set to 0 degree Camber, and Passenger is -0.9 Camber = Passenger bias cross camber of -0.9. People run with more camber than that and its ok, mainly for looks and fitting low offset tires, among other things. Im sure the car pulls mighty to the left. Camber bolts dont cost that much at all, its just 1 bolt and not like a camber plates or stuff. For instance: http://shop.microimageonline.com/Adj...olts-81270.htm But try loosening the two shock bolts and give a nice tug on the top of wheel to even it out. If the car tracks straight you know you got it at least pretty close.
| Skip alignment after only a 1.5" drop? | Henry_mak16 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-19-2013 03:44 PM |
| Vehicle pulls after alignment | salmonz | DIY / Maintenance / Service | 6 | 12-11-2010 05:17 PM |
| Alignment Question | gsf1200m | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-16-2009 10:35 AM |
| WOW What a difference an alignment makes!! | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-12-2009 05:29 PM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 07:01 AM |
