Old 08-19-2013, 02:32 AM   #1
Henry_mak16
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk
Skip alignment after only a 1.5" drop?
hey Yarisworld, i installed lower springs that gave me a 1.5" drop. However it seems that almost 2 weeks later my alignment still seems unchanged. my steerring wheel doesnt shake or lean nor do i have uneven tire wear. You think someone like me with a tight budget until a few months can skip the alignment and get one if there are ever any signs of need for alignment? y does a new ride height need an alignment anyway? thanks, no bs responses :p
Henry_mak16 is offline   Reply With Quote
Old 08-19-2013, 12:37 PM   #2
kou
Drives: 08 lb
You will be fine without the alignment for now.
Old 08-19-2013, 02:12 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
I waited probally 6 months after i lowered mine 1.5 but was very surprised when i did get a alignment how much it was off and that there was a noticeable increase in handling once i got the alignment done that made me wish i had got it done sooner.
Old 08-19-2013, 03:44 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
Your camber may be okay (within spec) however your toe will be off after dropping. Eventual tire ruining wear is imminent. Save money. Align now.
alignment tires springs
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 10:35 AM
WOW What a difference an alignment makes!! YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-12-2009 05:29 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
