What exactly are you trying to take apart? If it is to get the mirror glass off, you tilt the mirror up, get your fingers under the bottom, and pull straight out. Once you unclip the bottom, you lift up on the glass to release the top hooks. At that point you have full access to the internals and to the clips that hold the covers on.
#2 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
I'm trying to take apart the base and the mechanisms (practically take everything apart). i've removed all screws and T25 Torx (base), but the only thing hindering me from completing the process are the wires for the adjustment. i can't seem to find a way to remove them (without cutting them) and be able to put them back.
#3 | |
#4 | |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
Thanks Scott |
| Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 10:02 PM |
| manual vs. automatic | osmoq | Fuel Economy Forum | 82 | 01-26-2017 12:19 AM |
| Test drive 2012 Suzuki SX-4 A.W.D.. : 6 speed manual and C.V.T. ( w/ manual shift ) | Hershey | Off-topic / Other Cars / Everything else Discussions | 7 | 09-30-2011 10:54 AM |
| Automatic or manual transmission | bentjazz | Fuel Economy Forum | 31 | 03-03-2011 01:52 AM |
| Question: Didn't we have the Entire Service Manual in .pdf form? | Shroomster | Suggestions - Feedback - Questions | 2 | 10-27-2008 12:18 PM |
