Old 10-10-2014, 10:03 AM   #1
jcboy
Drives: Sedan 07
What exactly are you trying to take apart? If it is to get the mirror glass off, you tilt the mirror up, get your fingers under the bottom, and pull straight out. Once you unclip the bottom, you lift up on the glass to release the top hooks. At that point you have full access to the internals and to the clips that hold the covers on.
I was able to do that already, thanks to your guide in another post.
I'm trying to take apart the base and the mechanisms (practically take everything apart).
i've removed all screws and T25 Torx (base), but the only thing hindering me from completing the process are the wires for the adjustment. i can't seem to find a way to remove them (without cutting them) and be able to put them back.
Old 10-10-2014, 10:15 AM   #2
Sometimes those kind of mechanisms are built where they are not designed to be taken back apart.
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 10:02 PM
manual vs. automatic osmoq Fuel Economy Forum 82 01-26-2017 12:19 AM
Test drive 2012 Suzuki SX-4 A.W.D.. : 6 speed manual and C.V.T. ( w/ manual shift ) Hershey Off-topic / Other Cars / Everything else Discussions 7 09-30-2011 10:54 AM
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
Question: Didn't we have the Entire Service Manual in .pdf form? Shroomster Suggestions - Feedback - Questions 2 10-27-2008 12:18 PM
