der Zeck
you can run low offsets similar to the scions if you want
![]() ![]() Drives: 2007 Silver Toyota Yaris Sedan Join Date: Jan 2007
i am going to lower my yaris sedan with the tanabe DF210 springs. i just want to know if these rims will fit without it rubbing or causing any problems. They are 17" x 7" Tenzo Passion 5 ET42 wrapped in 205/40/17 Kumho Ecsta tires. Thanks in advance.
Should be okay with that setup.
i am looking at 15''/7'' et38 should i get 205/50 or 195/55.
yes trd sportivo.thanks
der Zeck
I like the updated guide Kimona!
thanks a lot kimona
![]() Drives: 2008 Yaris Sedan Join Date: Jan 2009
Performance wise, what would be the best tire, rim, etc size for a yaris puttin out about 150hp? thanks
![]() Drives: 2009 5 Door YRS Join Date: Feb 2009
Here is another good calculator, just in case you found the other ones a bit too confusing. This is also good to compare stock size with any aftermarket size.
http://www.miata.net/garage/tirecalc.html |
Top Notch!
Subscribed. Thanks!
![]() Drives: yaris Join Date: Mar 2009
those TRD wheels make no sense. With the TRD springs and the TRD Option 18x7.5, ET42, 215/35/18 = 23.9
can someone explain to me how these wouldnt rub big time? If 205 rubs on stock wheels, how is 215 with a 42 offset not going to rub? |
Pixitha
Does anyone know the exact dimensions of this wheel: http://www.trdsparks.com/displaypart...&parts_id=1101
I have the standard steel wheel black and ugly with ghetto hubcaps and wan't something else... I have 185/60/15 on the wheels right now and want to make sure the Toyota alloy wheels from TRD will still work with those and such? thanks! -pix |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
4x100
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
from a performance and wallet stand point, what is a recommended setup for standard springs and 1.5" dropped? I keep finding 15" x 6.5" is about as large without getting too heavy (i was hoping to go as light or lighter than stock, if that's possible while still going slightly taller and much wider). assuming 15x6.5, is 185/55 a good fit, or are the tires too skinny for the rim?
now that i'm looking around 205/50/15 looks more appealing on a 15x6.5
I have 205/50/15!
. CLA 250, 4MATIC |
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 98 | 02-18-2024 06:45 AM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
