Old 11-14-2008, 06:55 PM   #73
darthbauer
Not really here...
darthbauer's Avatar
Right now I am not lowered. If I do lower I will go with the TRD sportivo set up with the shocks and springs.
Liberate Tutemet Ex Infernis.
Old 11-14-2008, 07:22 PM   #74
kimona
kimona's Avatar
Drives: 2014 White VITZ
17x7.5 ET45, 215/40 rubber. Should be okay with TRD drop.
Old 11-17-2008, 09:31 PM   #75
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
u wont rub with that. any takers for my question above?
Old 11-17-2008, 10:33 PM   #76
kimona
kimona's Avatar
Here you go...777:
"...the one of a kind 15x8 has a 5 inch lip! This is done with a negative 27 offset, and can only fit the most extreme widebody fitments."
Old 11-24-2008, 07:30 PM   #77
kimona
kimona's Avatar
Originally Posted by DJexor View Post
Hello there, I see all sizes for a new Yaris. Does anyone know what the max offset would be on an 2001 TS model (oldest model)? Would prefere 17". Thinking of Work CR Kai 17x7 off +42
Don't know what the min/max wheel/tyre fitments are for the 2001 model, but I believe that 17x7, ET42 should work... no worries.
Old 11-24-2008, 07:36 PM   #78
Black Yaris
der Zeck
Black Yaris's Avatar
you can run low offsets similar to the scions if you want
Old 01-21-2009, 08:11 PM   #79
hafeez
Drives: 2007 Silver Toyota Yaris Sedan
i am going to lower my yaris sedan with the tanabe DF210 springs. i just want to know if these rims will fit without it rubbing or causing any problems. They are 17" x 7" Tenzo Passion 5 ET42 wrapped in 205/40/17 Kumho Ecsta tires. Thanks in advance.
hafeez is offline   Reply With Quote
Old 01-21-2009, 08:19 PM   #80
kimona
kimona's Avatar
Should be okay with that setup.
Old 01-21-2009, 08:38 PM   #81
kou
Drives: 08 lb
i am looking at 15''/7'' et38 should i get 205/50 or 195/55.
Old 01-21-2009, 08:41 PM   #82
kimona
kimona's Avatar
Are you lowered?
Old 01-21-2009, 08:41 PM   #83
kou
Drives: 08 lb
yes trd sportivo.thanks
Old 01-21-2009, 08:56 PM   #84
kimona
kimona's Avatar
Well, with 15x7, ET38, I would prefer to run 195mm rubber.
195/55/15 tyres sound like a good choice with your setup.
Old 01-21-2009, 08:59 PM   #85
kou
Drives: 08 lb
thank you i will start looking.
Old 01-21-2009, 09:04 PM   #86
Black Yaris
der Zeck
I like the updated guide Kimona!
Old 01-21-2009, 09:28 PM   #87
kimona
kimona's Avatar
Thanks. I did that a while back. Not complete yet. I'll get on it one of these days and finish it up.
Old 01-21-2009, 09:30 PM   #88
kimona
kimona's Avatar
You can find a bunch of tyre choices at this site: tires-easy.com
Sort by price, then click on shipping quote to find the real price. Shipping varies quite significantly by tyre.
Old 01-21-2009, 10:00 PM   #89
hafeez
thanks a lot kimona
Old 02-04-2009, 09:36 PM   #90
Marfulion
Drives: 2008 Yaris Sedan
Performance wise, what would be the best tire, rim, etc size for a yaris puttin out about 150hp? thanks
Marfulion is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
