Old 10-19-2014, 08:27 PM   #1
ajkochev74
Drives: Yaris
Thanks for the reply. Does that just involve cutting off the ABS and Brake LEDs? Doesn't just doing this still leave the codes active in the circuitry to be read by and OBD readout? Utah is pretty strict when it comes to yearly safety and emissions inspections, if the computer is still reporting failures to the computer I could still be in trouble using this.
ajkochev74 is offline   Reply With Quote
Old 10-19-2014, 09:26 PM   #2
You don't need to remove the LEDs. You can just cover them under the plastic card. A small piece of electrical tape will completely block them.
OBD is only emissions related, so you should not have an issue. The cluster would be able to report that it has the ABS light on, but that info can only be read using Toyota specific diagnostic tools (like Techstream).
HB GAUGE CLUSTER WITH RPM $125 TURBO YARIS Items for Sale by private party 17 12-12-2011 06:44 PM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
