Old 10-22-2014, 09:40 PM   #1
Kar98
Drives: 2011 Scion tC
Right, "line in cable" was the other name for it. My first CD player had two 3.5 mm out jacks, one was for headphones and powered, and the other one was labeled "line out" and unpowered because it didn't need to drive headphones and expect the system it got plugged into to provide power. Which the car stereos I had in the Europe of the '90s did. Advantage? You could keep the discman running on a pair of AAs for many more hours because it didn't need to provide an amplified signal, just a signal.
I guess that wouldn't work at all with the standard aux-in jack on a Yaris.
Kar98 is offline   Reply With Quote
Old 10-23-2014, 06:01 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
If you ever plugged a headphone into one of the "non powered" ports, you'd find that it is just the same as the headphone jacks but without volume adjustability. Ie, max volume.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Is extended warranty (6 yrs/75,000 miles) worth it for 2009 Yaris sedan? Marls General Yaris / Vitz Discussion 5 05-29-2011 11:23 PM
What music to you listen 2 in your yaris? YotaYarisUSA General Yaris / Vitz Discussion 126 04-27-2010 02:23 AM
