#1 | |
![]() ![]() Drives: NCP91 Join Date: Jul 2012
Hi guys.
I am aware of the effects of wheel torque-- and variations thereof-- on the brake disk and hub assembly. I am fairly confident in the torquing of my own wheels (120 Nm) and the accuracy of my torque wrench, being that it was recently calibrated by NIST-traceable equipment. I checked its accuracy on the weekend against my other torque wrenches and they are all consistent: variation within 0.7% or less of each other. ![]() My torque wrench is the Snap-on TQFR250E. My two others that I checked it against are Snap-on ATECH3FR250B and Snap-on ATECH2FR100B. With that being said, I think we can drop the speculation of improper wheel torque. Quote:
Kindly |
#2 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Eesh. Someone else with too much money in torque wrenches (at least mine are different sizes though :þ ).
WeeYari posted a nice link re: bigger front brakes. Re: rear brakes, unless you feel the drums are overheating and fading (causing the fronts to work harder), there is no point upgrading. See attached photo to get an idea just how little the rear brakes do (that's full braking w/ all-seasons). Just make sure the rears are always adjusted correctly. Use a little caution upgrading the fronts as bigger is not always better, and let's be honest, if you are braking hard enough to warp stock rotors you are probably going to brake harder with the larger rotors. My Mother warps rotors regularly. I have tried just about every combination of pads/rotors and even tried racing hardware at one point. End result is now I just throw the cheapest rotors in when she warps them, and use the same pads. My suggestion to you would be to try another set of OE sized brakes, and install cooling ducts. If you can keep rotors below their critical temp, they will not warp even if you hold foot on brakes at stop etc. I still think if I can take cars over the Coast Mtns full of camping gear and not warp, you should be able to adjust your driving to not warp brakes in flat Ontario. And I have owned cars that have undersized brakes on them from factory (the Yaris actually has pretty good brakes for what it is). Cheers. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| FS Rear Disk Brake Kit 2007-2011 Yaris | ARES_1 | Items for Sale by private party | 15 | 07-29-2014 09:19 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
