Old 10-24-2014, 11:01 PM   #1
vinooooo93
Drives: Toyota Yaris 2006 Sedan
thanks for the reply
Is there a video/ guide on how to do this?
I've tried removing the plastic covers from the top and bottom portion of the back of the steering wheel but it just won't come off
vinooooo93 is offline   Reply With Quote
Old 10-24-2014, 11:22 PM   #2
vinooooo93
Yep, i am an idiot... Forgot to remove two screws.. *facepalm*
So i tried gently cleaning the switches with paper and a screwdriver and it looks like it did the job. Dashboard lights, radio and tail lights are all back on but sometimes its hit and miss. Not sure if this is a permanent fix though.
Old 10-25-2014, 07:18 AM   #3
Look at my cruise control DIY that is linked at the bottom of my signature for how to remove the steering column cover. There are 3 screws that you have to remove.
Also, I believe that your Australian Yaris does not have a dimmer knob, but if it does, try adjusting that to see if the dash lights come back.
Old 10-25-2014, 07:25 AM   #4
vinooooo93
hi mate,
Well I used this video as a guide:
http://www.youtube.com/watch?v=qX5ABfOwOZU
However, for the Yaris, there are actually two screws holding those two plastic covers together. So what you need to is turn the steering wheel to one direction so that you can get access to the screw and remove it and do the same for the other side
UPDATE: I tried a second time cleaning it but this time using very fine sandpaper. With the the headlight switch in the off position, i took a long strip of sandpaper and slided it through to where the 'brass keys' makes contact. I then turned the headlight switch and gently moves the sandpaper from side to side. Turn off the headlight switch, removed the sandpaper, and i found quite a bit of dirt. I probably repeated this whole procedure 3 more times to make sure. Then i reassembled everything back together. Now, it works like a charm!
Old 10-31-2014, 08:21 PM   #5
Temjin
Drives: Yaris 07 Red
hi mate,
Thanks alot mate!
I haven't got to it yet, but had a mechanic to come over to logbook service both of my cars and had him to check out the problem as well. The problem was obvious and I was pretty certain cleaning the contacts would have fixed it, but he wanted to replace the entire headlight stalk plus labour for $500!!! :D
Will work on it later this weekend. But thanks a lot for the video card, I would assume the procedure is the same for Yaris.
Temjin is offline   Reply With Quote
Old 10-25-2014, 07:26 AM   #6
vinooooo93
Referred to this video http://www.youtube.com/watch?v=qX5ABfOwOZU
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
E mirror/ Radio not working, then central locking??? georgitanev In Car Entertainment + Electronics (audio / video / alarm) 1 11-10-2012 01:42 PM
Radio Lights Finapples In Car Entertainment + Electronics (audio / video / alarm) 3 02-01-2012 02:53 PM
E mirror/ Radio not working, then central locking??? bonnie_0915 In Car Entertainment + Electronics (audio / video / alarm) 2 07-17-2010 10:16 AM
