Old 10-29-2014, 06:05 PM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The remote wire is important. You also need to be aware that when you use more than two amplifiers, get a relay for the remote turn on duties. That'll protect the source if there's a short.
― Thomas Paine
Old 10-29-2014, 07:13 PM   #2
Yaris1212
Drives: Yaris 2015 1.5G
My setup is only 1 amp for 1 sub.. enough bass for daily driving or cruising. U suggest i also add a relay? Is that a fuse or? Explain further please..
Yaris1212 is offline   Reply With Quote
Adding USB ports for charging mr_miles DIY / Maintenance / Service 7 01-16-2012 03:48 PM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
Adding Cruise otterhere Performance Modifications 1 11-24-2008 04:11 PM
adding an Amp Keymaster In Car Entertainment + Electronics (audio / video / alarm) 5 02-16-2007 06:09 PM
adding DRL's..?? static808 DIY / Maintenance / Service 9 10-20-2006 04:15 AM
