Old 10-31-2014, 08:21 PM   #1
Temjin
Drives: Yaris 07 Red
Originally Posted by vinooooo93 View Post
hi mate,
Well I used this video as a guide:
http://www.youtube.com/watch?v=qX5ABfOwOZU
However, for the Yaris, there are actually two screws holding those two plastic covers together. So what you need to is turn the steering wheel to one direction so that you can get access to the screw and remove it and do the same for the other side
UPDATE: I tried a second time cleaning it but this time using very fine sandpaper. With the the headlight switch in the off position, i took a long strip of sandpaper and slided it through to where the 'brass keys' makes contact. I then turned the headlight switch and gently moves the sandpaper from side to side. Turn off the headlight switch, removed the sandpaper, and i found quite a bit of dirt. I probably repeated this whole procedure 3 more times to make sure. Then i reassembled everything back together. Now, it works like a charm!
Thanks alot mate!
I haven't got to it yet, but had a mechanic to come over to logbook service both of my cars and had him to check out the problem as well. The problem was obvious and I was pretty certain cleaning the contacts would have fixed it, but he wanted to replace the entire headlight stalk plus labour for $500!!! :D
Will work on it later this weekend. But thanks a lot for the video card, I would assume the procedure is the same for Yaris.
Temjin is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
E mirror/ Radio not working, then central locking??? georgitanev In Car Entertainment + Electronics (audio / video / alarm) 1 11-10-2012 01:42 PM
Radio Lights Finapples In Car Entertainment + Electronics (audio / video / alarm) 3 02-01-2012 02:53 PM
E mirror/ Radio not working, then central locking??? bonnie_0915 In Car Entertainment + Electronics (audio / video / alarm) 2 07-17-2010 10:16 AM
