Old 01-27-2012, 01:39 PM   #19
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
The who? Are you referring to a reflashing?
I am referring to the chip swap how-to to replace the TB chip when upgrading.
I'LL KEEP MY GUNS AND MONEY, YOU KEEP YOUR "CHANGE"!
ayuhuasca is offline   Reply With Quote
Old 01-27-2012, 02:25 PM   #20
Via Micro Image...
larger TB = more air = ECU sends more fuel = more power for the same a/f ratio.
1. drill out the rivets on both throttle bodies.
2. chip away the sealant from the idle adjust screw on the 1ZZ throttle body.
3. using small bolts and nuts, install the chip (black plastic assembly) from the Yaris onto the 1ZZ throttle body.
4. install the 1ZZ throttle body onto the Yaris, adjust idle screw
Old 01-27-2012, 02:30 PM   #21
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
Via Micro Image...
Thanks, do I have to take the TB out to get to the chip? Its already in there and I have the chip ready, just need to do as you mentioned.
Old 01-27-2012, 02:34 PM   #22
Yes, don't even TRY to do this with it still in place.
Old 01-27-2012, 02:37 PM   #23
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
Yeah I got a really badly rounded-off nut I am gonna have to figure out before I can finish this then. Getting a CEL, and wanted to rule this out.
Old 03-15-2012, 10:39 PM   #24
09sedan
Drives: 2009 yaris sedan
any guides on how to replace Front AND rear speakers on a 09 Sedan?
09sedan is offline   Reply With Quote
Old 03-31-2013, 11:50 PM   #25
Gearheadb6
Drives: 08' white yaris lift
ONE of the best DIY threads alive
Gearheadb6 is offline   Reply With Quote
Old 05-19-2013, 09:15 PM   #26
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
The rear drum brake adjustment posts....one "had" pictures....doesn't "work" any longer....this would be quite helpful to have!. TIA
frog13 is offline   Reply With Quote
Old 08-25-2013, 04:11 PM   #27
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I'm missing "automatic footwell lighting" ;)
Quite easy to get with maximum comfort, just attach e.g. LED-stripes to the seat frame and the plastic convers over the pedals and the same one on the passenger's side.
Second, have a look at the rather small connector on the far left side of the fuse panel near the steering wheel where three rather thin wires arrive.
The negative connector of e.g. the LEDs goes to the white wire with the black line on it, for the positive one you could just hook it to the purple wire, but for maximum comfort, I'd recommend a switch with a configuration that's called "on-off-on" if I remember correctly.
There, the second pole should be connected to the blue wire.
I have no pictures of this yet because I haven't had the time yet to apply this mod.
As soon as it runs fine, I'll post a tiny circuit that turns on the interior light only in the dark when it's necessary, thus avoiding unnecessary battery drain :)
By now, a somewhat larger project including Arduino, CAN Bus and DMX occupies me - might be finished tomorrow, next month or never ;)
dj92 is offline   Reply With Quote
Old 12-16-2013, 07:14 PM   #28
Ypai
Drives: 2011 yaris
Help
My red light for 2011 yaris came on sporadically what could be the reasons why? Help!!
Ypai is offline   Reply With Quote
Old 12-16-2013, 07:33 PM   #29
What red light?
Old 02-23-2014, 10:25 PM   #30
frog13
Tw200--excellent!
Revive this thread Yaris folk.
Old 08-21-2014, 03:36 PM   #31
chrisyse
Drives: yaris, 5 door, 2007
center heater vent repair
There's no airflow from my center heater vents of my 2007 5 door yaris. Where can i find removal and troubleshooting instructions?
Chris
chrisyse is offline   Reply With Quote
Old 08-21-2014, 03:44 PM   #32
chrisyse
No airflow from my center heater/ac vents
There's no airflow out of the center heater/ac vents on my center console. Where can I get a description of the vent system and /or how to trouble shoot the problem?
Chris
Old 08-21-2014, 05:27 PM   #33
Chris
You can download the service manual thanks to the Micro Image forum. The AC section of the manual cover the ducts, but most likely the cable which connects the knob to the flaps that direct the air has come loose. You can pull off the side vertical trim pieces with your fingers, then pull back the radio surround, and finally pull back the AC panel to check the connection on the back of the knob.
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 11-01-2014, 12:31 AM   #34
"G"
Drives: 2007 Yaris Hatch
Sedan rear speaker replacement?
"G" is offline   Reply With Quote
Old 11-01-2014, 07:50 AM   #35
Look at the "Audio Visual" section of the service manual, posted in the link above yours.
Old 11-16-2017, 11:29 PM   #36
frog13
Tw200--excellent!
My 2010 5 door hatchback. License plate bulb is a nightmare, no screws to remove to gain access.
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 05:10 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
