![]() Drives: yaris 2007 Join Date: Oct 2014
TAIL,REAR,LICENCE LIGHTS NOT WORKING
hey guys,
I have a yaris 2007 and this is the problem: No Tail, Rear and Licence light I don't know when this happend (I've been aware when another driver told me when driving at night). Checked the Fuse TAIL 7.5A PANEL 2 and replaced it but nothing changed. Note that -I am getting the warning tone when the switch lights are on and the door is open -Dash lights OK Can you please direct me on where the problem is thanks |
Check the PANEL1 fuse as well. On your car there are three fuses total involved: TAIL, PANEL1, and PANEL2
Does your car have daytime running lights?
Thanks CTScott for prompt reply
I did check both PANEL1 and PANEL 2 all ok checked also the fuses on Car hood all seem OK wonder where the problem is? Last edited by bouYaris; 11-05-2014 at 07:33 AM. |
Does it have daytime running lights (where the headlights are on even with the switch off)? The reason I ask that is that the next thing I will have you check will be different if it does.
No Daytime light
OK. There is one more fuse to check: TAIL NO. 2
After that, you can try bypassing the headlight switch by jumping the sky blue wire in pin 18 to the white wire with a black stripe in pin 12 on the headlight switch connector. The white/black wire is second from the left on the bottom row and the sky blue wire is 3 pins from the right in that same row. You can use a small piece of wire or a paper clip to jump them. If the lights come on when you do, then the problem is the switch.
Is TAIL 2 the 14th fuse from Up to bottom ?
it sait on my book TAIL 10A back light if if this one it has been checked as for the other solution Can you direct me on where to find them in my car Headlight switch where to find it thanks |
#8 | |
My fuse box looks like this
the one underneath the steering wheel http://i55.tinypic.com/2mdpjkm.png |
I'll try bypassing the headlight switch and let you know
Correction on the bypassing - I was helping someone from France with a 3rd generation Yaris and got confused with your issue. With you second generation the bypass would be to jump the green wire in pin 10 to the white wire in pin 13.
Also, in that case the fuses involved are just TAIL and PANEL2.
Scott
No luck I bypass jump the green wire in pin 10 to the white wire in pin 13 nothing happen picture of my connector https://drive.google.com/file/d/0B-A...ew?usp=sharing Last edited by bouYaris; 11-09-2014 at 03:35 PM. |
I didn't mention that when turning the switch
the light appear on the Fan and AC control and also on board and sound goes ON when door open see picture https://drive.google.com/file/d/0B-A...ew?usp=sharing https://drive.google.com/file/d/0B-A...ew?usp=sharing I didn't check any of the light bulb yet because I wouldn't think 5 buld will go off at the same time Any other alternative Last edited by bouYaris; 11-09-2014 at 03:33 PM. |
#15 | |
the front are off
the back and the licence also off the front small fog light ok |
Do you have a multimeter to be able to take some voltage measurements?
I can get one
which type of mesurement and how thanks |
| park lights not working | koppe | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 06-06-2025 02:24 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| Rear break/STOP lights, tail lights are out, plate lights working? | MzTyla | DIY / Maintenance / Service | 2 | 06-20-2013 07:56 PM |
| Fog lights, or parking lights stopped working | sylvermagyk | DIY / Maintenance / Service | 4 | 03-24-2011 05:13 PM |
| Taillights, signal lights, parking lights stop working | jamal1984 | DIY / Maintenance / Service | 2 | 10-13-2010 10:17 AM |
