Old 11-05-2014, 06:28 AM   #1
bouYaris
Drives: yaris 2007
TAIL,REAR,LICENCE LIGHTS NOT WORKING
hey guys,
I have a yaris 2007 and this is the problem:
No Tail, Rear and Licence light
I don't know when this happend (I've been aware when another driver told me when driving at night).
Checked the Fuse TAIL 7.5A PANEL 2 and replaced it but nothing changed.
Note that
-I am getting the warning tone when the switch lights are on and the door is open
-Dash lights OK
Can you please direct me on where the problem is
thanks
bouYaris is offline   Reply With Quote
Old 11-05-2014, 06:43 AM   #2
Check the PANEL1 fuse as well. On your car there are three fuses total involved: TAIL, PANEL1, and PANEL2
Does your car have daytime running lights?
Old 11-05-2014, 06:58 AM   #3
bouYaris
Drives: yaris 2007
Thanks CTScott for prompt reply
I did check both
PANEL1 and PANEL 2 all ok
checked also the fuses on Car hood all seem OK
wonder where the problem is?
Old 11-05-2014, 07:45 AM   #4
I did check both
Does it have daytime running lights (where the headlights are on even with the switch off)? The reason I ask that is that the next thing I will have you check will be different if it does.
Old 11-05-2014, 12:50 PM   #5
bouYaris
Drives: yaris 2007
No Daytime light
Old 11-06-2014, 11:19 AM   #6
No Daytime light
OK. There is one more fuse to check: TAIL NO. 2
After that, you can try bypassing the headlight switch by jumping the sky blue wire in pin 18 to the white wire with a black stripe in pin 12 on the headlight switch connector. The white/black wire is second from the left on the bottom row and the sky blue wire is 3 pins from the right in that same row. You can use a small piece of wire or a paper clip to jump them. If the lights come on when you do, then the problem is the switch.
Old 11-06-2014, 02:14 PM   #7
bouYaris
Drives: yaris 2007
Is TAIL 2 the 14th fuse from Up to bottom ?
it sait on my book TAIL 10A back light
if if this one it has been checked
as for the other solution Can you direct me on where to find them in my car
Headlight switch where to find it
thanks
Old 11-06-2014, 03:44 PM   #8
thanks
The fuses are in the image below. The headlight switch is the stalk that you use to turn them on and to signal. The connector for it is at the base of it, under the steering column cover. There are two screws behind the center of the steering wheel (turn it a bit to expose them) and one by the tilt lever for the steering column. Once those screws are out you can remove the lower steering column cover to get to the connector.
Old 11-06-2014, 05:18 PM   #9
bouYaris
Drives: yaris 2007
My fuse box looks like this
the one underneath the steering wheel
http://i55.tinypic.com/2mdpjkm.png
Old 11-06-2014, 05:44 PM   #10
bouYaris
Drives: yaris 2007
My fuse box looks like this picture
https://drive.google.com/file/d/0B-A...dXM/view?pli=1
Old 11-06-2014, 06:16 PM   #11
bouYaris
Drives: yaris 2007
I'll try bypassing the headlight switch and let you know
Old 11-06-2014, 07:45 PM   #12
Correction on the bypassing - I was helping someone from France with a 3rd generation Yaris and got confused with your issue. With you second generation the bypass would be to jump the green wire in pin 10 to the white wire in pin 13.
Also, in that case the fuses involved are just TAIL and PANEL2.
Old 11-09-2014, 03:06 PM   #13
bouYaris
Drives: yaris 2007
Scott
No luck
I bypass jump the green wire in pin 10 to the white wire in pin 13
nothing happen
picture of my connector
https://drive.google.com/file/d/0B-A...ew?usp=sharing
Old 11-09-2014, 03:15 PM   #14
bouYaris
Drives: yaris 2007
I didn't mention that when turning the switch
the light appear on the Fan and AC control
and also on board
and sound goes ON when door open
see picture
I didn't check any of the light bulb yet because I wouldn't think 5 buld will go off at the same time
Any other alternative
Old 11-09-2014, 08:34 PM   #15
and also on board
see picture
Do the small front light work?
Old 11-10-2014, 03:08 PM   #16
bouYaris
Drives: yaris 2007
the front are off
the back and the licence also off
the front small fog light ok
Old 11-10-2014, 05:39 PM   #17
Do you have a multimeter to be able to take some voltage measurements?
Old 11-10-2014, 06:54 PM   #18
bouYaris
Drives: yaris 2007
I can get one
which type of mesurement and how
thanks
park lights not working koppe In Car Entertainment + Electronics (audio / video / alarm) 13 06-06-2025 02:24 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Rear break/STOP lights, tail lights are out, plate lights working? MzTyla DIY / Maintenance / Service 2 06-20-2013 07:56 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
