Old 11-06-2014, 02:14 PM   #1
bouYaris
Drives: yaris 2007
Is TAIL 2 the 14th fuse from Up to bottom ?
it sait on my book TAIL 10A back light
if if this one it has been checked
as for the other solution Can you direct me on where to find them in my car
Headlight switch where to find it
thanks
bouYaris is offline   Reply With Quote
Old 11-06-2014, 03:44 PM   #2
thanks
The fuses are in the image below. The headlight switch is the stalk that you use to turn them on and to signal. The connector for it is at the base of it, under the steering column cover. There are two screws behind the center of the steering wheel (turn it a bit to expose them) and one by the tilt lever for the steering column. Once those screws are out you can remove the lower steering column cover to get to the connector.
park lights not working koppe In Car Entertainment + Electronics (audio / video / alarm) 13 06-06-2025 02:24 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Rear break/STOP lights, tail lights are out, plate lights working? MzTyla DIY / Maintenance / Service 2 06-20-2013 07:56 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
