![]() ![]() ![]() Join Date: Sep 2014
do you have a pícture or wiring diagram....
i understand, that i will check in motor area? can i connect between, the fuse and fuse box... |
#2 | |
#3 | |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
How do I confirm its the right wire to tap ? I tested out the wires. Got 12 v when the car is turned on as well when the car is in reverse. Thanks |
Then you are on the wrong red wire. The correct red wire will only have 12 V when in reverse. I did double check and it is the same - 3C-33 or 3D-29.
#5 | |
Here's a picture. Thanks
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| Scion XD LED mirror install pics aplenty | enviri | DIY / Maintenance / Service | 76 | 07-21-2019 02:10 PM |
| Blitz S/C being installed this Saturday! | LtNoogie | Forced Induction Forum | 179 | 12-14-2012 08:53 PM |
| ANYONE know where to tap reverse wire for ntd? | marcus | Performance Modifications | 10 | 11-23-2009 12:28 AM |
| Reverse Lights Wire Color? | NateDogg | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 02-01-2009 06:03 PM |
