Old 11-04-2009, 02:12 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ANYONE know where to tap reverse wire for ntd?
ntd throttle controller on the way thanks to 1NZYaris1 aka ray.. but curious about tapping the reverse wire under our dash really dont wanna run wire all the way the the back of the car..anyone?? thanks guys.
Old 11-05-2009, 02:23 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I was wondering the same thing. There's no need in having to go all the way to the rear lights, is there?
Old 11-05-2009, 04:02 AM   #3
1NZYaris1
1NZYaris1's Avatar
hi guy's if you give me a week , that's when i get home i will check it out for you .
Or if you are really lucky CT Scott might be able to tell you where the reverse switch is .
Unfortunitly due to my encounter with a rather painful beast , i am stuck in Auckland
till the 13nov , but we will see
Old 11-05-2009, 08:03 AM   #4
On the under dash fuse panel, you can tap it at connector 4A pin 30 (red wire) or 4B pin 22 (red wire as well) for both MT and AT.
Old 11-05-2009, 10:09 AM   #5
marcus
toyota
marcus's Avatar
beautiful...thanks guys..ill try that..
Old 11-15-2009, 01:56 AM   #6
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Just clear up my confusion both connectors work for AT and MT? Not just the 4B pin 22?
Thanks!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 11-15-2009, 08:18 AM   #7
Correct on both of the above - Works for 2006-2010 and both points (4B 22 and 4A 30) work for both MT and AT.
Old 11-15-2009, 10:15 PM   #8
andru47
andru47's Avatar
Great Thanks Scott, wanted to make sure since my NTD should be coming in soon hehe.
My Yaris: The Azure
Old 11-15-2009, 10:42 PM   #9
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
scott never ceases to amaze me with his knowledge and speed at answering these questions. lol
Old 11-20-2009, 10:50 AM   #10
DerFlosser
DerFlosser's Avatar
Scott is the man.
DerFlosser is offline   Reply With Quote
Old 11-23-2009, 12:28 AM   #11
andru47
andru47's Avatar
It worked thanks!
My Yaris: The Azure
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Reverse Lights Wire Color? NateDogg In Car Entertainment + Electronics (audio / video / alarm) 0 02-01-2009 06:03 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
