Old 11-11-2014, 03:20 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by phaznet View Post
I need winter tires! I've got an extra set of 15" steel rims in the garage. Car is on tein s tech springs, so 1.9" drop all around. What tire specs should I be looking at?
you can go with 175/65R15 for better snow traction instead of 185/60R15. but i'd say they both work well.
Originally Posted by MUSKOKA800 View Post
My 08 sedan came with 15" alloys and 185-60/15 rubber. I found used 14" steelies with winter boots (175-65/14) and find it a good package. It was cheaper when the boots needed replacement too. Ground clearance may be slightly increased with the 14's. This is good considering my drop. Less lip plowing is preferred.
You actually sit a bit lower on 175/65R14, as the overall diameter is a bit smaller than 185/60R15. Personally, i went with 185/65R14.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
FS: oem 14" steelies w/ winter tires thebarber Items for Sale by private party 5 03-31-2010 12:16 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 08:21 AM
Winter Tires? sketch182 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 10-23-2008 07:47 PM
