Old 11-12-2014, 02:17 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
On mine, i adapted a piece of thin metal to make the cutoff flat...like, Basically i just struck my fingers into the bulb socket with the metal piece and foil tape. It will never be flat cuz the projector bowl sucks. Basically these headlights are for looks, not for proper lighting as even the cheapest retrofit is better.
Instead of taking the bumper completely off, you could just peel the top off enough to get the lights off. And yes, you will have to do this to adjust the screws.
Check out my Build thread:
adjustment, halo, headlights, hids, projectors
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
Valve Adjustments bikeshox DIY / Maintenance / Service 28 08-13-2009 12:16 AM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
