Old 03-30-2007, 12:20 PM   #1
Pavel Olavich
Drives: 2007 Yaris LB
2007 Yaris LB - Valve Adjustments
Maybe I'm behind the times with modern 4 cylinder engines, but I was wondering about valve adjustments on the 1.5L engine. Looking at the maintenence schedule book, I could not find anything about adjusting the valves. Are the valves self-adjusting? Hydraulic valve lifters?
Anyone know?
Thanks!
Pavel Olavich is offline   Reply With Quote
Old 03-30-2007, 02:22 PM   #2
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Thumbs up ...just keep oil in the thing
The valves are not self adjusting. If you go by the track record of Echo and xA/xB drivers, then the valves do not require maintenance... its a Toyota...just keep oil in it, and it will run ...
fu_im_from_texas is offline   Reply With Quote
Old 03-30-2007, 04:14 PM   #3
Pavel Olavich
So then there is no preventative maintenence in regard to the valves?
Old 03-30-2007, 05:34 PM   #4
fu_im_from_texas
Drives: Liftback
Thumbs up 60k inspection
According to my Genuine Toyota 2007 Scheduled Maintenance Guide, at 60,000 miles a tech is supposed to inspect the valve clearance.
Unless I have reason to believe my valves are out of clearance (change in the valve ticking noise, lack of valve ticking, loss of power) I wont pay for the service...It hasnt been an issue on Echo's, or xA/Xb's.
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
